I'm probably posting something that most everyone already knows but I thought I would give my two cents worth.
If you don't want to read the rest. Just use Whink and follow the instructions on the label.
My sails had several deep rust stains on various panels. Nothing to bad at a distance but enough to bother a guy with OCD.
I decided to look up as much advice as I could find regarding rust removal from Dacron and other synthetic fabrics. I found a huge variety of info and advice with several products mentioned. I tried three very carefully and in relatively inconspicuous locations. I even asked the wife for ideas as she's a chemist.
Oxalic Acid (Bar Keepers Fried)(Rust Aid) works well on gelcoat and stainless fixtures. Due to it's light acidic properties with didn't seem to break down the rust in fabric. I will keep a can of Bar Keepers Friend for hull work.
Hydrochloric Acid or Muriatic Acid just stinks to high heaven and burns on skin contact. It reacts corrosively with most metals including stainless steel. This is nasty stuff and requires a 2% dilution. I'll stick to concrete cleaning for this stuff.
Hydrofluoric Acid (Whink) is the best overall rust stain remover for fabric. This stuff worked perfectly. The key to success is time and patience. I wet down the areas to be treated and applied the Whink directly. I made sure the area didn't dry during treatment. Depending on the severity of the stain it removed all the rust quickly. Once again patience and don't let it dry. When the rust was gone I washed the area with mild liquid detergent and plenty of water.
As with all chemicals proper safety should be taken. Reference the MSDS for these products. Dacron can easily be damaged by these products with over exposure. I don't recommend doing any sail cleaning in direct sunlight and besure to rinse before and wash after. Whink and Bar Keepers Friend are both available at Wal-Mart.
Good luck
