Serious Newbie questions.
I know a bit about sailboats but nothing about Hobies. Any and all advice greatly appreciated!
Just bought a 1978 14ft. Rigging seems in good shape. Sail is wasted and will need replaced. Trailer looks homemade and scary, I think there are pieces of sign post and guard rails on it. Need a new trailer!
Biggest part I don?t like is cracks on the tops of the hulls in the gel coat and the tops will also flex and pop when I push on them. They don?t crack but they do flex.
Is it normal for the fiberglass on the tops of the hulls to flex like this? Is it old and just become brittle? Was the Hull designed not to be walked on? Can I stiffen it some way?
What can I do to refinish the gel coat? It is Tan in color and looks like my Moms 1970?s Green fridge and stove. Can I strip the gel coat and paint it with a two part Urethane or primer that will soften the gel coat?
About an inch of water inside each hull and the foam blocks are intact. Can you fill the insides with that stuff they pump into your walls? Or Stuff in a can? I have used this procedure on Wooden Kayaks in the buoyancy tanks.
Has anyone ever tried the DIY sails at Sailrite?
Does anyone own a Castle Craft trailer? I?m leery of bolt together trailers. If so is it holding up well?
Already know the lesson on boats, ?Hole in the water?! Wife just deployed to Iraq, and need a project to take my mind off things. I think I have it!
Thanks????????.Bobby
