Posted: May 16, 2009 - 06:12 PM
I took the day off and went up to the lake, previous owner had riveted the adjustable crossbat to the tillers, there was always tremendous pull on the extending hotstick, so I finally drilled out the rivets and used a hacksaw to make measurement markings on the crossbar inserts. Got to the lake wind was 8-10 knots, sailed a bit, came back in because there was still some pull on the steering, adjusted the crossbar more in so the rudders were pointing slightly in, wind picked up to 15 knots, went on a screaming reach at warp 6.2, steering was perfect, no pull, port rudder kept folding up so I will have to tighten that up. Funny thing though, when I was trapped out on the port hull and the port rudder folded up, the steering got really sensitive, almost too sensitive. Some 'good ole boyz' came by on a opposite course on their pontoon boat, I spun about and hauled after them, catching up with them pretty quick. Made my day to see the look on their faces as I came past them trapped out, hull up, flying, warp 7. If only my photon torpedos were loaded, would have had those Klingons.
TurboHobo
H14T
P18
P16
