Measure your shroud line and subtract 1 1/2 to 2 1/2 feet, should be close. Better to short than to long. If you are going to use any on the fly trap adjustment blocks you need to allow for the length of those blocks. Remember that as you move to the front the line will get closer to the deck.
Murrays has them. Single
http://www.murrays.com/mm…Code=C-R-R&Store_Code=MS
double
http://www.murrays.com/mm…Code=C-R-R&Store_Code=MS edited by: skarr1, May 26, 2009 - 03:48 PM
