You will be much less frustrated with the Prindle rudder system is you use a high quality low stretch line for this and not just any old rope. I think it is 1/4 in as well but maybe 3/16. I would not use 1/8 way to small and will not be fun when trying to lock rudders in the up position. If you have the round pulls on your current setup the rope should be just the right size to barely slip through the hole and tie off. You should have one round pull for the lock down line on each rudder and one Tube or T shaped pull for each for the lock up line.
I tried the taping them to the old rope thing as well but only had limited success. I would study how the old ones are on very carefully just in case. I also color coded my lines makes it easier to tell which is which quickly.
Black line for UP and White line for down but whatever you can find in a high quality line. I would give these lines as much consideration as you would for your main halyard.
edited by: Quarath, May 29, 2009 - 04:20 PM
Member:
Utah Sailing Association
Check out "
Prindle Sailors" on Facebook.
