Posted: Jun 01, 2009 - 06:57 AM
I've replaced or worked on 16 hulls....word of caution~~ when taking off the frame from the hull use a rubber mallet or a block of wood~ short(2x4) if ya use a hammer, you could crack or break the casting.... One time I had to file down the pylon down in spots to get it to go on... you should see where it's hangin up or binding... good luck & take yer time with it........
and other toys.......
Bernhards Bay. ~~~~~~
