Hi guys... I have a problem & question
You already know the problem--LEAK, I have a comp. tip Hobie 18 mast and the only place where water is coming out is where the comp joins the metal mast, and it leakin at the grove/channel where the sail slides... Is it possible to fix the leak there or would I have to try to take the comp tip out?? How far does the comp slide into the mast?? ETC ETC ETC ~~~ Any info would help alot....
Thanks~~Paul
and other toys.......
Bernhards Bay. ~~~~~~
