Posted: Jun 15, 2009 - 01:13 PM
$500 for any boat is a good price if it doesn't need too much work. If the decks are soft, don't get it. If it is minor fiberglass or gell, and you can do the work, then go ahead.
Pros: Prindles are good, solid boats. They are very tough and durable. The beams are attached directly to the hulls, so they don't flex and feel very rigid. You could probably right a Prindle 15 easier than a Prindle 16 or Hobie 16, but that is strictly going on size.
Cons: There aren't as many Prindles out there as are Hobies--and the 15 is very rare. Finding parts will be your big issue. Prindle 15 specific parts like masts and hulls will be about impossible to find used. You will probably have to modify a 16 mast if you break yours. The steering is good on the Prindles, but the castings break and are hard to find used when you need one. If you get the Prindle, immediately start looking for castings. Used sails and tramps will be hard to find, but you can get those new. There is a jib on eBay right now and he is offerring a main as well.
