Sorry had to use the play on words for the subject line.
Question: When sailing on a close reach I can get the tell tales on my main sail set fine, leeward and windward flowing even and horizontal. Traveler on main is set out about 3-5 inches.
The issue is the jib. Even with the jib haulers brought in towards the centerline of the boat and the jib is two-blocked the all of the tell tales on the windward side are floating up.
Boat type is a hobie 16. My only thought is that the mast should be raked further back. Any input?
