Posted: Jun 24, 2009 - 03:20 PM
I did a trick on my rudders this winter. After messing with a Preval sprayer and acid brushes I discovered my new friend the foam brush.
Rudders are actually easy to refinish and since gelcoat is a polyester resin it works best. Mix up your gelcoat and thin a little with styrene monomer and brush the gelcoat on. I used finish gelcoat and didn't have to work with styrene wax or mold release. Just brushed in on, let it cure and sanded/polished.
Make sure the rudders are clean and wax free. I would remove all oxidation and litely sand with 300 grit as prep for the gelcoat. Wipe them down with acetone to clean them. Brush on the gelcoat with the foam brush and then sand and buff to your desired finish.
I would lay the rudders across saw horses and work one side at a time. don't try to coat them hanging. The foam brush leaves a relatively smooth finish and looks great. You'll need several brushes.
If I can help you any more just ask. I was intimidated by gelcoat and all the ratios at first but once I started working with it I realized it's not too hard to figure out.
