Design for Mast holder for trailering a P16
Anyone have a good design for the rear mast (on rear cross brace) holder for trailering? Prindle 16. Boat goes in the water this week end.
Thanks, Harry
I have a 6" piece of PVC. It's about 8" long. Cut a slot in one end for the mast to rest in. On the other end, shape it to set on the cross beam.
edited by: skarr1, Jul 01, 2009 - 05:20 PM
got a pic< would love to see it
I made the same, cut a "V" slot in top, cut out a strip the entire length of the PVC, fits over traveler track, mast drops into "V"
TurboHobo
H14T
P18
P16
on my H18 i used a milk crate and bungees
a life jacket makes a good rest as well.
I used a vertical pole with a receiver style connection to the trailer. I also used a quick release pin to make connecting and disconnecting quicker.
I like this style because the mast is not resting on the boat. I live on a 1 mile long dirt road with lots of pot holes and with a mast cradle that rest on the boat it was hard to stop it from sliding side to side on the travel car rail due to the trapoline style not allowing me to secure the mast around the rear cross member.
Another reason i like this style is because the added insurance that the boat will not slide off the back of the trailer due to braking or acceleration because the vertical mast support acts as a stop for the boat. I usually tow the boat more than 50 miles to get to the water and this makes me feel alot more comfortable about doing so.
edited by: kinlawk, Jul 01, 2009 - 09:29 AM
I use one of those foam noodles. Not the 3" diameter one, I found a 6" diameter one at Wal-Mart. I cut off a one foot section, and rest my mast on that. Plus, when it gets worn or lost, I still have three more feet to use. All for $2.99.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=63142&g2_serialNumber=1&g2_GALLERYSID=a500b50218f3d2d1fb07ca18583d5126
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=63138&g2_serialNumber=2&g2_GALLERYSID=a500b50218f3d2d1fb07ca18583d5126
Instuctions
http://www.thebeachcats.c…pictures&g2_itemId=63131
And Andrew will tell you not to use bungee cords like the ones in the photos.
edited by: skarr1, Jul 01, 2009 - 04:25 PM
Hey kinlawk can you email me at gcwilson777 at gmail dot com i need to ask you a couple questions thanks.
It needs a coat of paint but this is what mine came with
http://i493.photobucket.com/albums/rr297/gcwilson777/photo-7.jpg
http://i493.photobucket.com/albums/rr297/gcwilson777/photo-8.jpg
Skarr/steve, that's a nice looking mast cradle. It doesn't get more durable than PVC.
Thanks for posting the picture.
Dang me!... After searching for something to buy and not finding anything I liked, I just went out to my garage and made a mast cradle for trailering that fits on the back crossbar of my Prindle 16... Looks a lot like the plywood one in the pics above. Total cost = 50 cents worth of electricity to run the sabre saw and drill. Everything else was scrap wood and spare drywall screws... Tomorrow I'll paint it using old spray paint... What fun!
Mike
1975 Prindle restoration project "Sanchah"
Retired Teacher
Newbie Sailor
if you want to get fancy, here's what is used with my h16. overkill probably but never any problems.
http://www.thebeachcats.com/pictures/?g2_itemId=88398
Mike Conway
Hilton, NY
i used a 4 in. 45degree pvc pipe joint. cut out a square piece on either side of the bottom to fit over traveler track. than set the mast on the top and pencil and cut out semicircles on the top to fit the angle of the mast. i use it on my solcat 18 and my nacra 18 square and it works great. tie it down to the crossbar and the mast when traveling.
H16-71388I use one of those foam noodles. Not the 3" diameter one, I found a 6" diameter one at Wal-Mart. I cut off a one foot section, and rest my mast on that. Plus, when it gets worn or lost, I still have three more feet to use. All for $2.99.
That's using your noodle!
I did the same, but used two pieces.....one on the mast and one on the rear beam...which cross each other. Trim each a little to fit the contour somewhat....works great and is cheap and easy.
Edited by rattlenhum on Aug 12, 2013 - 12:26 PM.
Clinton, Mississippi
Hey Jerome... Can u send me a pic of your mast cradle?... The noodle design. Thanks
Frank
Prindle 15/Hobie 16/Hobie 14T
QuoteI used a vertical pole with a receiver style connection to the trailer.
Same here.I use a 5'-0" stick of Uni-strut (available in the electrical aisle at HD) in a receiver made out of 2" box tubing. It has a bow roller on top with cradles. I put a foam bumper on the receiver to avoid damaging the hulls.
When I push the mast aft and pin it to the step the masthead is about 8 feet of the ground. That's a good starting height for raising.
http://www.unistrut.us/
'82 Super Cat 15
Hull #315
