Hello Pierre-André.
I too have a Mystere 5.5.
my jib sheets were frozen (could not adjust the angle) and they were set very low (perfect for on the wire, but impossible for crew to un-cleat). I had to learn / teach crew how to FLICK the sheet to uncleat. it is all about technique (unless you can adjust the angle...).
In your jib block picture, you are missing the 4 way adjuster system. with out it, you can not move the blocks inward (for upwind/close hauled) and outward for downwind?
It looks like you also have a barber hauler ring in the picture that is not being used.,..
If you need the info on how it should be rigged...here is a link to a thread that talks about how to rig the 4way and has many pics...
If you need more info. i will post it for you.
http://www.catsailor.com/…lat&Number=177106&page=1
Your mast.... hmmmmm i would double check all your trap wires and shackles (on top of your mast)... i really dont think you could over tighten your side stays (and have a lose front stay/halyard) to the point you cant turn 90*. If you over tighten the halyard... you can lose the ability to rotate... but i doubt at 80*.. you would notice the tightness at any movement. but i could be wrong.. please keep us posted on what you find.
PS do you have anything between the mast base and the ball (on the beam)? I use an orange juice bottle top with some silicone spray in there to avoid wear and tear and to act as a bearing...
edited by: andrewscott, Jul 07, 2009 - 10:13 AM
