I just fixed both of my rudders. I have the white plastic ones for a h-18 1980. I drill 5/16 holes down the blade through the broken pieces and blade. I clamped them and the rudder between two boards with c-clamps. i then tapped 3/8 coarse threads in the hole. the plastic melts when drilling and that is why i drilled such a small hole. you will have to drill as deep as you can and pull the drill out a bunch to remove the melted plastic. my rudder had a piece of plastic the was bent in the way of other pieces from sitting right. so i cut it out. now there is a gap. then i screwed 3/8 allthread all the way down and cut it off flush with a hack saw. then i grinded it smooth. then i taped wax paper around the area and i filled the gap with fiberglass resin. in the morning i removed the paper and sanded it smooth. then i sanded the rudders with 120 and wiped the with mineral spirits. i painted the rudders white with rustolium paint and a roller(i painted the whole boat with it, works well and cheap
). I have yet to test this fix but it seems strong enough(i own 4 sailboats and i had to build rudders for all of them.
) good luck. feel free to critisize. i am sure that there are better ways to avoid spending $135 per rudder blade
