This late 70s vintage fixer upper Sol Cat is my first catamoran. After a month of repair and finding missing parts I have had it out a half dozen times. The last time out in 15 to 20 knot winds on Lake Ontario, I managed to pitch pole it and put the mast in the water. I was very impressed with how quickly planting the bow brings the whole show to a stop. Anyway, with out belaboring all the things I did wrong to end up in the water, here is important part:
The boat mast ended up pointing in the leeward direction, my partner and I (both about 175 lbs each) immediately stood on the stern bottom hull, grabbed the righting line and leaned back. (both sails were uncleated).
We seemed to be loosing ground, I stood on the hull and continued leaning while my partner attempted to swim the mast towards the wind. While this was going on, the mast was sinking.
By the time he joined me back on the hull, the mast was banging on the bottom. From the angle we were at, I'm guessing 15 to 20 feet deep.
The boat eventually drifted so the mast was pointed windward, but she was not showing any signs of righting.
Our local fire department rescue boat came out and righted in one uniform tug. I moved on the tramp as it was righting. That's when fire hose pressure level water sprayed out of the main halyard sheave hole. (The main halyard runs up the inside of the main.) It sure looked like the whole 30 foot of mast was full of water. It sprayed for 20 seconds(?).
As far as I can tell, this mast is essentially an open cylinder. and water can easily enter through the halyard line hole in the top of the mast. It seemed like the boat was doomed to turtle within 5 minutes.
I'm looking for suggestions. I'm considering getting a Mamma Bob. (Will the installation of a Mamma Bob make the leaky mast a non-issue.)
Thanks in advanced for your help.
