Since mine came from Pete I recommend you listen to him. Just use good quality line you don't want to skimp here.
I did make one adjustment I like you might consider while you are redoing it though. I rigged my up line with the black rope I got from Pete when I bought a new rudder casting from him. Then I rigged the lock down line with some good white rope. Not necessary but but easy to tell at a glance which one you need to pull.
edited by: Quarath, Jul 13, 2009 - 12:35 AM
Member:
Utah Sailing Association
Check out "
Prindle Sailors" on Facebook.
