I just bought an 86 Hobie 16. I was raising the mast, and had it almost up, when the base came apart. Luckily it was almost up, and I was able to get it seated without losing control of it. I managed to get it more-or-less back together and get it down safely.
Here's a picture:
http://s159.photobucket.com/albums/t131/jpwu/Hobie%20Cat%2016/?action=view¤t=IMGP0113.jpg
As you can see in the picture, there's a BOLT holding the mast base into the mast. You can't really see it in the picture, but the aluminum below the holes that the bolt goes through is ripped out (C's instead of O's).
A couple of questions:
- Looking at some other threads on here, I see people describing similar problems, but they describe it as having RIVETs popped out, rather than a bolt. So, I'm guessing that a previous owner had already damaged the mast, ripping out the rivets, and replaced them with this bolt. Should it be riveted in?
- I was thinking of cutting off half an inch or so off the bottom of the mast, drilling new holes, then replacing the bolt. I saw a thread where someone else suggested this solution. Will this work? Should I use rivets (I'd have to buy a rivet tool) rather than the bolt?
- In addition to riveting or bolting the base together, what about the idea of using epoxy? It should make it very strong. Would it matter that I'd never be able to take it apart again?
Any help appreciated!
Thanks!
