I know I can buy new but I was hoping I could get some suggestions first.
First the cam cleats for the jib need a new spring. I can't tell if mine are too old to rebuild. I can see the delrin balls from above, so I not sure if it is a Harken 150. Any ideas ?
Second
The pulley wheel is decomposed inside the jib sheet traveler car (both sides), I guess the wheel can't be replaced.. any cheap alternatives to the full $42 replacement ?
Third: It looks like I have a traveler control mechanism, but the end cleat is broken. It is screwed into the bar, but I can't seem to find one of these. Should I just replace it with a V cleat ? I am not sure I under stand the purpose of this thing.
Finally I have replace the downhaul cheek (another decomposed wheel)block. It is just $12, but what kind of rivet gun should I buy ? Also do I just drill out the rivet heads to remove the old one ?
Thanks for any tips
