Posted: Jul 24, 2009 - 02:42 PM
I had the inner brass piece on the rear beam pull out. This was on the stern side of the rear beam. After repairing the fiber glass, I installed a piece of 1" X 1" aluminum angle under the deck, from the inner to outer strap by using longer bolts through the straps. That was about 6 years ago, still holding.
I think there is a lot of upward force on the rear beam from the main sheet.
The front beam on your boat should not have moved in.
There is a bolt on each side through the beam into the hull to keep the beam from rotating under the pressure from the mast.
edited by: skarr1, Jul 24, 2009 - 01:44 PM
