I don't have any extras like a spinnaker or any other setup other than mast main and jib really. I setup the boat at the beginning of the season at home. After setup The only pin I really need to put in each time are the forstay, boom, and rudders. The rest stay in pretty much the rest of the time. Now I don't race or run in real heavy winds so I don't do much adjusting of the mast rake like some do. I lost the pin I was using to step the mast but found it works better and is less hassle to just put a 1/4 bolt with a wing nut through it for few minutes it takes to get the mast up. Any way the point was you may not need to stripping every piece of rigging every time you put the boat away. My rigging pretty much stays attached for the season and gets coils up on the tramp and attached to the hiking straps for trailering.
Plus if you look at west marine they have some of the ring dings.(or keychains) that have a bent in section making it easier to get them on and off as well.
Member:
Utah Sailing Association
Check out "
Prindle Sailors" on Facebook.
