In a 7, maybe 10 knot wind we had a flying hull and a few seconds later heard a loud BANG--and the mast dropped.
Upon inspection, all rivets had broken off clean. They were not ripped out of the holes, they just broke.
It's possible that there was some minor movement as the mast hound was not a snug fit, but all the same I find it bewildering that a few flimsy aluminum rivets are supposed to hold the entire load, which is probably a ton in a high wind.
Any ideas? Similar experiences?
Unless someone has a better advice, I will use a 1/4 inch bolt for the top rivet holes, a single one that goes through the mast, and drill at least 6 more holes to take additional rivets. Also make it the mast hound a better fit first.
