That is not the gooseneck, that is the MAST STEP. The GOOSENECK is that little contraption that is attached to the boom and then attaches the boom to the mast using the sail track.
A common problem and one easily fixed, first, check your DOLPHIN STRIKER, the stainless steel rod that protrudes from the bottom of the mast step, unscrew from mast step and make sure the threads are still good, if the threads are stripped on the mast step, big problem as this is made from aluminum, you will have to get another, either new from Murrays.com or used, check e-bay. You might have to bend the dolphin striker straight. If the threads are good, screw back into mast step, do not overtighten.
Second, cut/drill out rivits, whoever replaced the rivits last time drilled them out and oversized the hole, the rivits pulled out from the crossbar, they did not break, you're going to have to use rivits a size bigger, stainless steel or monel rivits are recommended because of the stresses placed upon the mast step. Clean area on crossbar before attaching mast step, make sure there are no burrs on the aluminum, attach mast step, re-rivit, make sure the rivits are tight this time, additional rivits can be drilled if neccessary.
On page 2 of Technical Help Gallery is an album labled "Replacing H16 Mast Step", check it out, will give you a visual guide, will also help with the dolphin striker rod issue, this has to be loosened in order to raise the dolphin striker in order to unscrew mast step. Hope this all helps
Keep on sailing...
PS
never, never secure the cat on the trailer by hooking onto the dolphin striker with the winch strap, like motor heads do, this will bend the dolphin striker and puts un-neccessary torque on the mast step, and can cause the dolphin striker to strip threads/pull out of the mast step.
PPS while you're at it, go ahead and fill out some details on your profile so we know where you're sailing.
edited by: turbohobo, Aug 02, 2009 - 09:37 PM
TurboHobo
H14T
P18
P16
