I'm refurbishing a 1973 Panthercraft Tornado. Planning on adding a self tacking jib from Harken.
And custom making a Spinnaker kit from a windsurfer mast someone specified 13'1" hope that's right since I already cut the mast to be the new pole. What I'm looking for is maybe someone to send me some pictures of the lines and cables on one that's really set up right meaning max performance etc. Like where to install the various blocks cables lines etc. Otherwise I'll be guessing from various photos and drawings I've found. Any suggestions would be appreciated. Great boat. My email address is seakayak2@yahoo.com Thanks - Mike
P.S. Found that raising and lowering the mast is a cinch with temporary side stays (cables using the jib halyard attached to the front cross bar.) and a temporary hard floor made from using 5 2 by 4's and 2 2' by 8' plywood sheets Works great in case someone could use the suggestion sometime. Nothing quite like a bent mast to screw up your day. Works perfect.
edited by: strategy, Aug 11, 2009 - 12:30 AM
