Posted: Aug 12, 2009 - 12:26 AM
Just bought my 1st H16 Thursday and had its maiden voyage Sunday. wOW! I couldn't believe the pull on the tiller and the lovely whirring sound at the rudder. NE-ways the mast step link was bent when I bought it, so I hammered and formed it back into shape in order to get on the water, however the spring seems to be shot and I should replace the link since it started to crack. I noticed on some replacement step links that the kit no longer includes the spring. Does the spring do anything? I noticed that when stepping mast, that the mast tends to "pivot over center." In other words, the mast goes up fine, but it seems the front of the mast base (male) tends to get caught up going into the mast step (female) once nearly upright. I then have to pull the mast back a bit for it to seat. 1) is this normal 2)is this probably just because the link probably wasn't bent to factory angle (I tried my best hammer & vise skills) 3) does the spring help prevent this and if so, why doesn't the new link kit #21380001 not include the spring?
