Hey guys,
Going to be losing my regular crew soon, so I need to consider some aspects of singlehanding, one of which has been talked about here ad nauseam.
Which means, of course, I'm going to talk about it some more. Check my reasoning, if you would, for the following solo rigging scenario:
- Park in a spot with the trailer angled slightly down at the front
- Walk the mast back, lay it on extended ladder several yards behind the boat
- Fit mast base casting to step (in my case a ball), put in pin
- Tie line to forestay, run line forward around winch and back to tie off on the mast, somewhere within reach
- Make sure all rigging is clear - raise the mast
- While holding mast in place (fairly easy once up) cinch up line attached to forestay around mast (tied off to something on mast or just around mast?)
- Carefully dismount boat and tie off secondary line from winch or thereabouts to spot on mast (pad eye for main halyard?) acting as a temporary forestay
- Untie line attached to forestay and secure to bridle
- Untie temporary forestay
Okay, using this method am I going to have a fun day of singlehanded sailing, or am I going to put a nice deep canyon in the roof of someone else's extremely expensive vehicle and, possibly more importantly, look like an idiot?
Thanks for your revisions, suggestions, muffled laughter.
