Posted: Sep 08, 2009 - 11:10 AM
You might also work to make sure the knots holding the battens in are fairly smooth, and the battens are not longer then they need to be. Also you can work with your jib and main halyard securement to the mast to make sure they are not easy to catch by the battens as you tack. It won't eliminate the problem but can reduce it.
Also if there is moderate wind you can often let the jib sheet out after you tack and get the battens to pop across the mast. I have never seen the furling H16 jib, but it may have a slightly different sail shape since it doesn't have battens.
