Posted: Sep 19, 2009 - 04:03 AM
the cheap plastic ones are vinyl .
they can be repaired if the brake but basically they get brittle with age and if they break 1 time, they probably will again... i would spend the 130(each) and replace or even better ... upgrade
as per the trap gear/ people sell used hobie equip all the time on this site and others... you should be able to find that gear used...
but you may also want to hold off on more expense a little while and hone your sailing skills before you add the extra challenges of the trap (unless you sail in big air.. and then you will want/need the extra weight to hold down the hull)
Its not that hard.. but takes practice
edited by: andrewscott, Sep 19, 2009 - 04:03 AM
