Snuffers! yes most cat's use them (instead of bag launching).
there are 2 different kinds that are common, mid pole and end snuffer. Most use mid pole snuffers now..
I believe the end pole system allows you to go more around a mark (during racing) and gives a slight advantage, but the mid pole makes it much easier to fix a sail that has fouled (you can crawl/slide out to the end of your bow to fix it, you can't on an end pole system unless you are a contortionist).
I personally use a Capricorn Aluminum ring, mid pole system. It cost me about $250 2 years ago, but has gone up to around $450. Many people LOVE the SNU system (
http://www.gobarefootstudio.com/snu_08.htmlit looks good and the guy who makes them is great to work with. I almost got one but had a wind surfer mast as my spin pole and it was tapered so i wasn't sure if the snu would fit it.
See the image below
edited by: andrewscott, Oct 07, 2009 - 10:28 AM
