my starboard hull on a '84 H-16 takes on about a quart or two of water after sailing 1-4 hrs generally digging the hulls in pretty good. Port is dry. When I drain it out, small bits of fiberglass come out also, like it's slowly delaminating inside. It's had some small repairs, both fiberglass and that cheap composite marine-tex stuff before I got it. I've never done a leak test (like with the blow dryer and soap bubbles) but there are no obvious holes or soft spots outside. Sorry no pics available.
-should I leak test it and patch small areas with marine-tex again?
-the hulls look crappy with the repair should I take them off, grind down and re-glass/paint?
(I'd like to preserve the old style Hobie 16 decal though)
-or is this normal for an older boat quit worrying and go sailing, just drain it dry each time
thanks
eddiecat
Hobie 16 (restored)
