Posted: Dec 18, 2009 - 11:29 PM
Yurdle,
I really don't know how to articulate to you the techno-babble of what is happening, 'cause I ain't good at it, but, I will try.
I'm not talking about it bending up further, as that will surely kill it.
Is this a loose rig or tight rig? If it is a loose rig it is very easy to bend this piece, and that is one way it happens, and then you run the risk of further bending and failure. Not Good. If it is a tight rig it is less likely to accidentally move up or down. But, let's not focus on if or if not it is going to move up or down, because that should not be your concern. Your concern should be this weak chain in the link, which can cause catastrophic failure as described above. The day that piece bent it was weakened and fatigued. At some point there will be that unwelcome significant load (either compression or tension, without the spreader bar moving) that will do it in.
If you run a tight rig, (we run 600-900 lbs. on each of our diamonds) you put pretty significant loads on that tiny shoulder of alloy. That area is further and constantly being loaded and unloaded in copious ways, i.e. downhaul cycles, mainsheet tension, on and off the trapeze, stuffing waves, etc. It is further complicated by the fact that one ear could carry more load that the other due to the bend, and/or the holes being out of alignment while sharing the same clevis pin. The problem is further enhanced with a loose rig. Picture this, your sailing in heavy air traveler out, hard mainsheet, tight wave sets, and two large adults on the wire. The leeward spreader/diamond is under a tremendous load. Skipper screws up, drops the mainsheet because he lost balance while stuffing a wave, both skipper and crew teabag hard, and the boat luffs up. So what do you think the loads were on the weak link in the chain? Thats right, they were all over the place. What do you think the loads would be on that leeward spreader when double trapped upwind, downhauled, and hard sheeted main and jib? That piece, depending on rake, can also cycle between tension and compression. I can describe plenty more situations that exercise forces on that little piece, and you can hardly imagine what it has gone through over 20-25 years. I'm willing to bet there is also corrosion/pitting where the stainless steel clevis pin contacts the hole in this piece. Conclusively the bent and weakened piece is further compromised by age.
So, to satisfy your curiosity of why, I'm not sure I know the answer, or if any of the above is any help. What I can tell you is through time and experience, I have learned these things, and they tell me to replace things like this or replace your standing rigging every x# years, etc. The real issue is that there is an obvious problem that can lead to a bigger problem, and my experience is that it will cause rig failure, sooner or later.
I wouldn't add an "I told you so". I've lost rigs and it is a sickening feeling, and you can get hurt. Got that t-shirt also.
