3 questions for Ron & Philip...or anyone with knowledge. What is the hole in top left of the rudder casting for? It is only on one casting, the other does not have this hole.
Also, MUUMP, with regards to your post above, could you enlighten a Noob as to what CE & CLR regard to... center of effort? can't think of CLR other than a rust cleaner
How much free play is OK between rudder & casting? Right now I can slip 2 credit cards between casting & rudder, there is a bit of play if I wiggle the rudders sideways. Should I attempt to build the rudders up, wrap waterproof tape around the casting where they rub? What do you cosinder excessive? I have read about shims/washers, wouldn't it be better to build up the are where the free play is (the worn white line in the casting cutout in picture above). That would provide much better support for the rudder as opposed to a shim/washer on the bolt.
Picture 2 shows the Pivmatics that I have. The rudder down line that came with the boat is shown. That is as far "into" the Pivmatic as I can get it. It doesn't seem like it goes down far enough into the teeth of the jam cleat. Are these cleats worn & should be replaced, or is this line diameter to large? Can anyone sow me a picture of what a line fully engaged in the cleat looks like? Pulling this line tight (assembly is not mounted on the boat, I can't do the same job with it on the floor as I could on the boat)then pulling on the rudder to simulate water force, seems to show the line slipping/stretching...with resulting displacement of rudder towards the up position, which would result in weather helm.
RON, what line would you recommend, diameter & type, (no stretch nobby) They are pretty short lines, cost wouldn't be much.
I also realize the connection between the rudder tubes & the cross tie is not as shown in the assembly manual, a few parts from Murrays, or D Berger will cure that.
Wolfman, this is what my adjustable cross tie looks like, looks pretty simple to adjust & get rid of any rudder misalignment. Damn, I wish I had the boat at my home garage, I'm itching to tweak.
Wolf. here is a shot of the pivmatic & adjustable tiller
Is this enough "bite" or is the jam cleat worn, or line to lasrge?
edited by: Edchris177, Jan 09, 2010 - 10:51 PM
