In a gusty 15 to 25 knot wind, I somehow lost grip and held on to the tiller not to fall off, causing the cat go downwind. The resulting centrifugal forces going into a curve made me pull even harder on the tiller and we accidentally gybed... sound familiar?
Anyway, the cat immediately turtled, I'd say after only 20 seconds. By the time we jumped on the centerboard it was already too late.
On former capsizes, the mast did float as it _is_ properly sealed. I will however check that later statement.
My best guess is that the 25, perhaps 30 knot gust was just too much blowing on the trampoline. I was assured by members of this forum that "your mast should float for at least 20 minutes"... I'm gonna sue you guys :)
We stood on the leeward hull and pulled on the righting line, and the weather hull did come out of the water a few inches, but not more. The main and traveller were uncleated.
My question: If the traveller had been in the middle and the main sheet should have been tightly cleated, would there have a chance of bringing her up from the turtle position?
A motor boat helped pulling but they stopped for whatever reason once the mast was floating on the water. From that position we installed our home-made righting pole and brought her up by our own. This is another reason why I claim the mast is sealed properly. There was no indication of water in the mast.
Dan
edited by: catdan, Jan 14, 2010 - 05:04 PM
