Thank you for the replies.
MUMMP, (looking at the picture),are you saying the shackle that is attached to the tack should be attached where the Harken block is? Toss that block, & use one up near the top, where the swivel is. The lower shackle would secure the tack, then all you need is a halyard that runs through a small block at the top (& back down to the cleat shown in the picture)to raise/tension the jib.
I'm thinking if setup that way, you leave the forestay rigged, & by uncleating the purple line in the picture you could drop the jib, unzip it & remove it if you were leaving the boat sit for a week or so.
Andrew, or MUMMP, do you have a close up picture of your setup.
Please don't misconstrue my post as an argument against what you do. The only furler I have seen was on a Hobie Bravo, I really am ignorant of the details. If I do it I want it done right, & the simpler the better. The picture of the Nacra rig in Murrays is pretty bad.
I can't remember exactly what the adjuster on my forestay looks like, I THINK it might be a 10 holer, will look this Fri when I drop by the cottage.(Damn, I'm glad I took everything apart & stored it inside)
Plus I just got in from Santiago, Chile yesterday. The 32C sunshine was nice,
the being up 27 hours with 3 hours bunktime in the attic of the B777 not so nice. It rather reduces the processing power of my older 386 brain
edited by: Edchris177, Feb 02, 2010 - 08:15 AM
