continuous trapeze / j hook question
Im having a hard time figure out how to setup the trapeze. posted a while ago and didn't get much response, I have since done some more looking around and it appears I have to j hooks, for a continuous trapeze but cant find any images of them in use to figure out how to set em up. any help here is greatly appreciated. Thanks all.
-Matt
http://www.murrays.com/mm5/graphics/00000001/01-1120.jpghttp://www.murrays.com/mm5/graphics/00000001/30-021.jpghttp://www.murrays.com/mm5/graphics/00000001/01-0137.jpg
From Murrays http://www.murrays.com/index.htm
Does this help?
At the top the line runs up to your mast hound. Your harness hooks to the ring on the left. The shock cord on the lower right goes to the same trap wire on the other side of the boat Usually under the tramp from one side to the other. There are several other types of rings and hooks that you can use.
http://www.murrays.com/mm5/graphics/00000001/01-1212.jpg
Here is a picture from I believe, Airbornes setup. The trap wire comes from the masthound down to the trap handle. Below the handle is a short line (blue) that runs through a small block. One end of the line is connected to a metal loop, the other end to a bungee cord that runs through the front beam, to the trap line on the other side,or under the tramp to the opposite side.
The bungee keeps the line retracted & snug when not in use. To use, grab the metal loop,(dogbone) & hook it under the metal hook on the harness you are wearing,(see picture of harness above). As you hike out over the side, the blue line will run through the block til it hits that little black rubber thingy that is tied onto the blue line. This will limit how far you can "fall" towards the horizontal. Moving the little stopper serves as an adjustment.
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=35656&g2_serialNumber=3&g2_GALLERYSID=b232d1ebd198f0ca1511d0559be4bc41
I have never seen a continuous trapeze system in use on a catamaran. I'm not sure they would work. If you only have the J hooks you are probably better off starting new with one of the systems shown above. Anyone else have experience wiht a continuous trapeze (one you don't have to unclip and reclip into)?
Ya I cant find much info about it. It came with one j hook attached to each wire, a shock cord from j hook to j hook, and a bearing and clamcleat on the shock cord. So my thinking is you use kind of the setup shown above but instead of unclipping you just slide the clamcleat off the j hook and along the shock cord to the other j hook. but that would only work if the shock cord was not under anything or clipped on to anything... I think im going to end up going with a system like above. was just curious if anyone had any experience with what im talking about...
http://inlinethumb29.webshots.com/3484/2946445100104341373S600x600Q85.jpg
You should NOT have 1 shock cord for both hooks/dog bones.
You should have 2 or separate shock cords... The reason why, if that shock cords breaks when yer both traped out, yer both gonna go~~ Who is gonna maintain the boat?? no one!! I brought that up with a friend of mine... He gave me that "DHHHH LOOK"~~ He doesn't sail anymore, stupid idiot left his cat on shore for the winter. The ICE WAS HUNGRY.
Need I say more?????
and other toys.......
Bernhards Bay. ~~~~~~
popeye,
The system Matt is talking about is one in which you never have to unhook and rehook your harness when tacking, it just slides with you from one side of the boat to the other.
Matt, like I said not many cat sailors are familiar with it. :) I think it is mostly a mono boat thing where there isn't much distance between the two sides of the boat. I would be interested in seing how it would work on a cat, but it looks like a PITA. Probably better off with a more standard rig (like you said).
D.
edited by: Wolfman, May 02, 2010 - 12:05 PM
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=62070&g2_serialNumber=4&g2_GALLERYSID=1af2d2db57c881ea66c30617c47acdd1
mattie411Im having a hard time figure out how to setup the trapeze.
-Matt
Matt, I must have missed what boat you have. You've received some good info on this thread but if we knew which boat exactly you could receive better instructions and help. The system for cats is pretty much the same on every one, what is different is how they attach to the hulls and where the bungees run.
Please fill out your Profile with boat and location info and you may get some local help as well.
Will fill out info, didn't realize it wasn't filled out. I'm in the Capital Region of Canada (Ottawa area). As for the boat, I'm not sure what kind it is. no marking on it and cant find any that look like it. 15 foot hulls, two ports (middle and back) in both. 25 foot mast. It came with a Hobie sail but i assume it was purchased later than the boat as it is fairly new. The trap is attached the each hull via awning track. There doesn't seem to be any apparent spot for the shock cord to hook up to so I'm just gonna run it under the tramp and setup an adjustable rig. Anyone have a recommendation for the best place to get trapeze stuff?? Below is a pic of the boat. I have since taken it apart to redo the hulls and replace hardware.http://inlinethumb30.webshots.com/45981/2360974680104341373S500x500Q85.jpg
Wow, that is a SWEET boat! Are you sure it is just 15 feet long? How wide is it (that might help also)? That hull shape looks fairly modern!
Not 100 percent sure its 15, it was advertised as 15 foot. I will take some actual measurements tomorrow. Ive got a suspicion it is built from a kit or something as you can see a seam along the length of the hulls.. the inside looks like sprayed fiberglass...
great looking cat
QuoteAnyone have a recommendation for the best place to get trapeze stuff?
thebeachcats.com - classified?
murrays.com
http://store.catsailor.com/
http://www.apsltd.com/c-3825-trapeze-harnesses.aspx
ebay
craigslist
etc
edited by: andrewscott, May 02, 2010 - 09:34 PM
The shape, daggerboard wells and lack of a jib make it look like and F17 to me. It certainly looks longer than 15 feet and I doubt those hulls were made from a kit. All fiberglass hulls look like that on the inside. It could be an early 2000s Nacra F17 or even a Hobie 17/Fxone (not familiar enough with the early 2000 hobies to tell from teh hull shape). If you can find the serial number on teh back of the hulls we can probably figure out the year and make. If it is an F17, man that will be a rocketship!!
So It's definitely only 15 feet, Right on the nose. The shape does look a lot like the f 17 though. Did they make a 15 foot version at some time? or a similar boat in 15 foot length? I could get the exact width because I have her all apart right now fixing her up, but I would put it around 7 feet. No serial number to be found.
Its the wrong shape to be a hobie or a prindle of that size. It could be a Mystere 4.3 Uni, you are in the right location for it. Anyone else have any ideas?
dats not a mystere 4.3
the 4.3 is a skeg boat
Hmm, I have no idea then. Maybe it is a kit boat or an early F16?
Looks kinda like a Supercat.
I think you are correct. This looks like a Supercat 15 UNI.
Dan Berger has one of these, maybe he can help out.
Here's a link to a pic of his cat.
http://www.thebeachcats.com/index.php?module=pictures&g2_itemId=64747
Hmm not quite the right shape. Maybe a different year?
edited by: Wolfman, May 04, 2010 - 04:52 PM
It is very similar to that one but its got more of the nacra shape to the hulls.... I emailed the guy I got it from to see if he had any more info on it, No reply yet. I also ordered stuff to setup a high - low adjustable trapeze on each side, forget the j hooks.... really looking forward to the summer. I'll be sure to post some pics of her when we get her back together, and any news I find out about her history. All the help is really appreciated. hopefully we can find out what she is.
That would be great, looks like it will be a fun boat. Does it actually have dagger boards? I thought I saw dagger board wells but can't really tell.
Ya it has dagger boards.
not a Supercat at all because the bow tangs are too far back and the bottom of the bows are not round (too squared off).
I got my trapeze stuff in today to setup a high-low adjustable on each side. cant wait to get this baby back together, just waiting on the hatches, and one more coat of paint and clear then back together. Here is the pic I drew up for the graphics, the white is done and looking good, gonna tape it up once we have a few nice days....
http://inlinethumb16.webshots.com/47183/2664772890104341373S600x600Q85.jpg
The only boat I can figure out that it could be, is silly. It looks like a Nacra 14sq. But I don't think that they were ever manufactured in North America.
only thing is that they are boomless. not sure if they were always built that way or that is a new thing.... its definitely that shape though. I never did hear back from the person I bought it off. It's a mystery!
How about some more pictures, boards, rudders, boom, mast base, top of mast?
Yeah, pics of the rudder and mast step system would be very helpful. They tend to be unique to each manufacturer. It could be a kit boat or prototype of some sort after all, there are quite a few kicking around out there. Heck there is a climax 18 for sale on the classifieds here, there probably were only 3 or 4 of those ever made.
haha, I'll take some more pictures as it is going back together. I can post some of the painting process as well and the rebuild. We finished the trailer and it looks great. hopefully it warms up this work so we can continue the hulls...
Here is the system I got. I may have to adjust the length of the adjuster line but its just what I had so I can cut it shorter if need be. Any suggestion please let me know!!!
http://inlinethumb14.webshots.com/43917/2178484990104341373S600x600Q85.jpg
http://inlinethumb52.webshots.com/27763/2692222200104341373S600x600Q85.jpg
looks right to me (with the exception you noted of to much line. you can remove the extra once you've had it on the boat and see what is correct).
i have a t handle after the stopper ball on my set up. its pretty easy to fumble with that little stopper ball when trying to pull yourself up (adjust higher) to get out of the way of a wave or similar... if you have weight on it (you on the wire hanging over the side of the cat) and it gives me a much better grip. the only reason i keep the ball on there is if you slip and the entire system pay's out (lowers you)... the handle can jam in the cleat/ or be out of reach for me
That definitely sounds like a good idea! I'm not sure I'm using the right rope for it. I've got soft hollow braid so its got some give to it, just what I had on hand. Will that be alright or should I swap it out for some stiffer rope?
to be honest not sure what hollow braid is.. but if it has no core and is only a jacket i would go with something stronger.
you can use cheap xls (extra low stretch) and shouldn't cost much at all.
u should inspect your trap line (and cables) for frays every now and again. I have heard several stories of people taking unexpected "baths". the guy i bought my cat from told me he was on the wire and noticed a few freys, went to pull himself in and they went "ding, ding ding - SPLASH" i wish i saw that.. :)
one note about the t handle. i use one just like pictured above. i had to cut down the end a bit to fit my line through it. you will never get that line you are using through a handle without drilling..
yah just looked at it a little closer, it does have a core but is soft and just feels like it will stretch a lot. going to swap it out for some stiffer stuff...
Yeah, make sure you use quality rope for those types of controls (sta-set or a relatively inexpensive sailing rope works fine).
No hardware store stuff or your hands will never forgive you. It's also no fun when a cheap line gets wet and stretches to twice its normal length dragging your butt in the water.
D.
QuoteNo hardware store stuff or your hands will never forgive you. It's also no fun when a cheap line gets wet and stretches to twice its normal length dragging your butt in the water.
well it's no fun for the dragee, but it's a hoot for the other skippers :)
Well, I got the paint finished and got it all back together. had it out for a sail yesterday but the wind was pretty light and I forgot to put the one end cap on the beam so it was filling up with water. spent all day today sealing everything with silicone and making sure its all sealed tight, filled the hulls with water and didn't have any leaks. So if it cant get out it shouldn't get in right... anyway Here is a pic of it on the grass after I was done working on it. Will get an action shot next time we take it out. Turned out really nice.
http://inlinethumb61.webshots.com/5820/2704541610104341373S600x600Q85.jpg
just found out my uncle too some action shots
http://jgleed.com/LaurinBoatLaunches/images/dsc_4763.jpg
Few more here http://jgleed.com/LaurinBoatLaunches/index.html
You can see in a couple how low the hull is riding, when we got in it was over half full of water.. lol
edited by: mattie411, May 30, 2010 - 05:33 PM
Wow! That is a thing of beauty! Great job on the boat!
How did the hull fill with water? Did you find the leak?
well the one cap had come off the end of the tramp beam and I suspect the water was going in there where the bolts go through the hull. I Sealed it up today and tested it by filling the hull with water.. there wasn't any coming out anywhere so I'm pretty sure I got it. No nice wind in the forecast though so may be a few days before I can give it the real test. We also forget to paint the rudders, Other than that everything worked out great, Cant wait for some decent wind to get the hull flying!!
Not that it matters now but I wouldn't test for leaks by filling the hulls with water, that could cause more problems than it's worth. Usually you attach a piece of garden hose to the drain plug and blow into it, someone can then look for leaks or brush areas with soapy water. You can also use a hair dryer or vacuum, but even that much pressure could damage the hulls.
Hmm, interesting that the bolts go through to the inside of the hull but weren't sealed. Hopefully that solves your problem, like I found, even small cracks can cause large amounts of water to enter the hulls while you are moving. I would suggest using a really good marine sealant/adhesive like 3M 5200. That stuff works awesome for sealing rivts and when putting fittings in the hull (like eye straps for a trapeze etc). Once dry it acts like a super strong flexible adhesive, quite impressive.
The rudders look fine from the pics anyway. Cool shape.
That is one sweet looking boat, I would like to know more about her.
Im pretty sure thats a Freestyle 474. It looks almost identical to my boat and the description seems appropriate. Only thing is it looks like the mast might be added with the Hobie sail. Not positive tho because the only side shot is it in the grass and iv never had mine sit in the grass. The rudder shape and the assembly look identical. What kind of hobie sail do you got on there? I'd like to add an a newer sail to mine.
edited by: ryman522, May 31, 2010 - 04:40 AM
Im not sure I just bought the boat this year with no info about it. The mast is 25 foot, I can measure the sail if you want
So I was out sailing today on the wolf beast and had a catastrophic tramp blow out. The whole side and half the backed ripped and almost went for a swim. We were moving a long pretty good when it happened so it was a pretty funny scare, lol. We made it back alright was just a little tricky sailing the one way after that. We also almost pitchpoled, I shifted my weight to the center so coil up a loose rope and the wind picked up a lot just as I shifted and we started to lift and with my weight in the center the low hull went under somehow we avoided the pitch-pole still not sure how, lol So if anyone has an old tramp lying around let me know, were desperate right now and cant afford a new one with a baby on the way. all in all a fun day , and NO leaks!!
-Matt
Oh man that's not good. You will probably have to get one made up custom. There are a few guys who do them relatively inexpensively. Tampa Catamarans could probably hook you up for $200ish. Unlikely that you will be able to find one that fits used or cheaper than that.
