NACRA 500 Main Sail
I just sailed my new to me NACRA 500 this weekend, the main sail went up fine and ring locked in at the top, however..how do you get it un-locked without tipping the boat over? Any help would be appreciated.
If this is an internal halyard (one that is inside the sail track on the mast)take the foot or bottom of the sail out of the track, uncoil the main halyard, pull the halyard so that the ring will raise up higher than the hook and then WITHOUT RELEASING ANY PRESSURE rotate the mast approx 90 degrees grab the bottom of the sail, do not allow the mast to move, pull down on the mainsail and release the halyard about the same time while holding the mast over. If you allow the mast to go back, or let off on the halyard, more than likely it will fall back on the hook. Just remember that the ring must be above the hook, the mast rotated, and pressure kept on the halyard before you start to pull down the main.
Thank you very much...I will give that a try.
nacratampabayI just sailed my new to me NACRA 500 this weekend, the main sail went up fine and ring locked in at the top, however..how do you get it un-locked without tipping the boat over? Any help would be appreciated.
Where do you sail?
