Posted: May 06, 2010 - 09:27 AM
Glenn, We unpin as soon as the mast is up. And then connect the forestay to the bridle. That way the mast rotates that extra little bit and you get a tighter connection on the forestay. But that is if the 16 uses the same mast set stepping system as the 18.
