Under normal conditions, the mast rake/rudders are setup so the cat slightly pulls into the wind when letting go of the tiller.
However, if the mainsail is not optimally trimmed, e.g. traveller too far out, and the jib is well trimmed, the boat actually goes straight, or even has slight tendency to go downwind.
Is this how it should be? Or should the boat always pull into the wind, completely regardless of sail trim?
