Posted: May 26, 2010 - 08:54 AM
as it's only a 14' it will probably only have a tiny jib so simply tying the sheets to the clew should be fine
but on a bigger boat with a bigger jib, like the 5m2 jib on the hobie16, the jib can get so loaded up with wind that it is almost impossible to pull in and cleat
so that's why you'll find a small block tied to each side of the jib clew
by going to the block on the jib and then back to the block on the boat you have geared down the system by a factor of 2 and halved the loads. much easier to pull in
get on a 30' boat and you need a winch to do the same thing
