Dave there is thread just a few days ago, with some good ideas for stepping, the thread is here:
http://www.thebeachcats.c…ms/viewtopic/topic/12709
I like SKARRs idea, & though someone slagged the 2 men on the tramp, I find it worked very easily for my 5.7.
I'm only 170 lbs, with wet hair & PFD, & find the idea of grunting a mast up by sheer force is a case of large shirt size, small hat size. Better to think like an Egyptian, & use the laws of physics, rather than my back. That said I only raise mine once or thrice a year.
You have lots of Cat time, no reason you can't solo a Nacra or like. I was practically new to Cats when I got my 5.7. I can't really power it up solo when the wind gets to 15mph, but with even a 120 lbs on the wire, it is amazing how much speed you can attain. Even driving the 5.7 hard with two on the wire & myself braced against the traveler base it won't pitchpole. Yesterday with my wife on the wire & 20+ mph we stuffed into a wave that put the hull down to the beam. Wter everywhere, & off course we lost speed , but it surfaced & took off again.
I use a furling jib, mostly because I have a constricted place at my dock, & a rock breakwall. That helps immensely when docking. I always use the jib, unless I'm experimenting, just to gain knowledge of how to run the boat if my jib were to explode 20 miles from home.
At each tack, as you move across the tramp, move the traveler line with you, hang it by the rear beam. Get the boat around, roughly sheet the jib to where you think it should finally be, get on the wire, & haul in the main. I keep the main looped across the upwind knee, so it stays there, & the jib sheet lies by my feet. I have the tiller in one hand, main in the other. It is easy to do a head up a bit, hold main & tiller in one hand, do a knee bend, grab the jib or traveler line & adjust, then just straighten your legs to trap fully out. It takes a bit more organization, but tacking isn't a high speed event if you are soling, lots of time to do 3 or 4 things as the boat comes slowly around. Make an SOP (standard operating procedure) out of it, & two days later it will all seem old school.
I flipped it quite few times the first year, now I only flip when we are screwing around, or deliberately living on the other side of the edge, seeing just where the edge of the envelope is, then trying to stretch it just a bit.
If the wind is right, I can right the 5.7 solo, with even a 100lb kid along it is easy with just the line. Solo I bring a bag, but have learned that I don't need to struggle with 100+ lbs of water. I can almost right the boat, so really I only need a few lbs in the bag. Place it on your chest, or lift it & hang it from a hook, that you can clip just above a knot on the line. As you know, once the mast is 6" out of the water you're golden.
The 5.7 is a handful solo once the wind is over 20 mph, I might like a 5.0 better for those days. I looked at the New Nacra 4.3 in Oz, but I'm not sure if I could swing it as checked baggage, though I did manage to check a 5.7 sail bag,with main, jib, along with beam, V brace, & a steamer trunk of other parts.
