Spinnaker Set-Up Pix
Looking for some ideas on aftermanrket spinnaker set up. What you have you done, got any photos you can post? Will be looking to possibly do this for Prindle 18-2.
John Schwartz
Ventura, CA
Here are a couple of examples using a Nacra 5.5 not exactly the same but the general idea is there. One uses a bag launch the other uses a end pole snuffer. Mid pole snuffer rigs are what everyone uses now.
http://home.comcast.net/~ragenpl/nacra/NACRA_55_SLOOP_SPINNAKER_USING_INTER_20_SNUFFER.htm
http://home.comcast.net/~ragenpl/nacra/nacra_spinnaker_1.htm
I made my spin setup on my P19, pics can be found at:
http://www.thebeachcats.com/index.php?module=pictures&g2_itemId=72912
The design was done after studying the manuals for the N20 and the F18 (all MFG's)
Some quite good technical writeups can be found at:
http://www.hobiecat.com/support/tech/sailboat.html
Materials:
Spin pole was bought at a local aluminum supply house, 24', 1.5" .065" sidewall T61 anodized and cut to 12'6"
Hardware from West Marine, wires I made at Wast Marine, end caps and pin from Murrays.
A mid pole F18 setup would be ideal for you IMO
Good Luck
ButchGI made my spin setup on my P19, pics can be found at:
Materials:
Good Luck
Thank, saw what you did and it go me to thinking.
John Schwartz
Ventura, CA
