I have a 1983 Nacra 5.0 with a few small holes in the hull seams where it appears the previous owners were beaching the cat. I have seen examples of bottom jobs from rounded hulls such as nacra 5.2's but not sharp V skegs like a nacra 5.0.
It seems to me that the hulls are created in two sections and then glued/epoxied together. If this is the case do I need to glass the entire bottom? Towards the center of the hulls, its about 1 inch where the gel coat has been sanded off over the years; however, the front sections, the width is less than a fourth of an inch. It would seem to be to narrow to add glass without taking a lot of the current gel coat/glass off. Does the damage look minor enough that I can fill the small pin holes and short gaps with something like Evercoat Formula 27, add some glass to the wide section, and then gel coat the bottom? Not having seen a nacra 5.0 new, I'm not sure how much glass has been removed over the years from the beachings its had.
I've attached some photos to show the extent of the damage.
edited by: bh3700, Jun 16, 2010 - 05:49 PM
