Adding Floatation to a NACRA
Does anyone know of a good way to add floatation to a NACRA? Got a big hole in my starboard hull on the 4th of July a couple of miles offshore in the gulf we made it back in ok but that hull was underwater the hole way back. Its got me thinking if I hit something that breeches both hulls that boat will likely sink entirely. Its a 1990 Nacra 5.5sl Edited so Andrew Scott thinks Im cool! lol!!!
edited by: fa1321, Jul 07, 2010 - 02:14 PM
A 1990 5.5SL "SHOULD" have flotation in it like these:
http://www.thebeachcats.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=18403&g2_serialNumber=6&g2_GALLERYSID=eb64bac26aa3193fab5f0c44391e7ef8
I have not opened it up yet but are you saying this should be installed already?
pontoons are for pontoon boats.
hulls are for cool people :)
HMMMM? Yeah, I got no responce to that one Andrew stay cool I guess.
hahah.. thanks for the edit.
edited by: andrewscott, Jul 07, 2010 - 04:01 PM
Checked my boat there is not any floatation in the hulls. Any suggestions on what I can add for floatation that will fit thru a 4" inspection port? I though maybe those pool noodles or something like that.
Whatever you do--DON'T fill the hulls with foam! The foam will retain water and destroy your hulls from the weight.
Noodles are good and light--and won't make any noise clunking around. If you could get some bladder in there you can inflate, that would be good, too. Air is the best floatation.
You can get packing material that is really just air packets. That would work, too, but I don't know the durability of the plastic.
There has been a lot of joking about filling the hulls with ping pong balls, but that isn't a reality. I just get a kick out of envisioning the slick of pingpong balls it would make if the hulls crack in half!
packing peanuts would be just as bad!
We put two 15" beach balls into each hull.
andrewscottpontoons are for pontoon boats.
HA....the pontoon word drives me crazy
Oh yeah, what about small mooring balls or boat fenders?
u would need a bunch of fenders .. they would add to much weight (IMHO)
I would think beach balls would deflate quickly in my climate
unless you (or your crew) enjoy blowing up things in your hulls ... icon_eek
I must admit.. .i left my cat on anchor last sat and went out for over an hour ride on my friends pontoon boat (he also has a 6.0 mystere) and it was great.
andrewscottu would need a bunch of fenders .. they would add to much weight (IMHO)
Yes it would...maybe someone needs to come up with one of those self inflating devices? icon_lol a hydrostatic release so if the boat goes down a few feet it activates and floats back up!!! Thats how some life rafts activate on ships.
As for pontoon boats I often looked at them and would say if I were to get a petro chugging, BP mess making boat it would either be a pontoon boat or one of those Chris Craft style wooden boats $$$$
Whatever I use would need to fit thru a 4" inspection port.
I like the pool noodle idea. $1 each at Walmart. no issue with fit, and easy to replace after a season to keep things from getting "icky".
http://sanantonio.craigsl….org/boa/1887500937.html
Ha! Craigslist has everything I guess...but Walmart is cheaper :)
edited by: turtlecat, Aug 10, 2010 - 07:43 PM
craigslist is pretty awesome but Im in Houston.
yep. I was thinking of air bladders (actually what I was looking for on the net) but after thinking about it, if its a catastrophic event, whats to keep the bladder from being puntured as well? The noodle seems like a safe, cheap solution.
Btw, last I saw you just had a pinhole leak left. All good now?
Todd & Frank helped me patch that but I still have a real slow leak. The next thing we are going to try and add some filler to the resin and just paint the dagger well with it. But as I said the leak is real slow so I can sail it as is for now. I adjusted my mast rake and moved my weight forward last sail and it sailed like a total diffrent boat I was surprised of how balanced it was when flying a hull. It just felt right! When's the 6.0 coming to 10 mile?
I wish it were there right now! This weekend is San Antonio for a show...It just seems to go on and on. Glad your able to hit the water. I'm afraid I'm going to have to dial in my boat (and me) all over again. IF I get to head out, I'll definitely give a shout.
You going to pick up some flotation while your in San Antonio?
HA! At 7 bucks a tube - Wally world looks like a better alternative. The pool noodles are about 3" dia, so it should have enough room to bend and get them into place. So you adjusted the diamond wires for more agressive rake? Do you know what tension your running?
How many noodles would give adequate flotation? I would guess more than I would want to put in a hull.
Nacra 5.2
Well NMMA requires 10% of "capacity" of a hull to be in flotation. I dont think that's the aim on this though. Pfd's would cover occupants and the balance is just to keep the boat in a neutral boyancy state. My boat is 420#, and its actually pretty hard to "burp" all the air in the chambers - So to answer your question - I have no freakin idea :)
There is another product other than the "pool noodle". Polyethelyne foam would be more quantifiable in its flotation factor, as its used currently in the industry for this purpose.
I have seen people floating around in the pool with 1 noodle so I think 2 in each hull would keep it from sinking.
just remember "people" are neutrally bouyant as we are mostly water...fiberglass and aluminum - not so much. Just things to ponder. Let me know what you decide on!
A testament to Nacra buoyancy:
A few weekends ago I took four people out into Lake MI with 15 - 20+ westerly's. I rushed the set up to accomodate the scedule of one of my crew. (He only had an hour) We were out ripping for that hour (two on the trap) and as were were heading back to the beach my wife asked "Why is the boat sinking?" I then felt the plugs in the pocket of my vest! I had everyone go forward and we landed safely. It took 6 guys to ease her far enough up the beach to drain the hulls which were full.
wow. i got no more than 100' (solo) before i noticed something was very wrong (plugs not in)
but then again, my boat has the most rediculious floatation foam i have ever seen... i doubt a flee could float on it.
See here:
http://www.optimumhealthreport.com/foam.jpg
We were in light winds and the hole in my dagger well was bigger then the drain plug hole. The starboard hull was a few inches under water all the way back to shore.
If you were "ripping", & the plugs were out, you would actually be draining water. When I worked in the Arctic we never bailed out our aluminum boats, just get them going & pull the plug, the water would mostly drain.
Archimedes principal gives us flotation, ie the amount of water displaced equals the amount of flotation.
So,to calculate flotation of noodles, you only need to know the volume they displace.
If you buy the cylindrical ones, the formula is:
V = pi r2 h so lets assume the noodle is 3" x 48"
V = 3.14 x (1.5x1.5) x 48 Note:3" diameter = radius of 1.5"
V= appx 348 cubic inches, that = 1.5 gallons. Water weighs 8.35 lbs per US gallon, so you get appx 12.5 lbs flotation for each noodle, minus the weight of the noodle. My kids noodles have a hole down the center, so you would have to plug each end to get the full value.
Remeber, that the noodles will give you zero flotation, if they are just left floating around, until they are actually submerged, meaning the hull is full, . I would try an inner tube from farm equipment built for spraying crops, the kind that have very skinny, very tall tires. These tubes can be worked through a pretty small hole, then inflated to low pressure. The tube will push up/down & wedge in place. Just google calculating volumes to get an idea of how much they will displace, you will be surprised at how much a lightly inflated 6" tube will float. Tubes are cheap to buy, tough, & a couple of them easily worked through a 4-6" access port in each hull will float the cat.
Plastic water bottle...bags of them...http://www.theplastiki.com/
Put a heavy duty plastic liner, like a battery liner and put the bottles in that way.
The H21 has factory installed bags with foam blocks in the forward hulls, they take up a good of the space forward of the cross beam.
They are not secured to the inside of the hulls, they move around, but from the outside you cant notice it. The ones in my boat dont have any evidence of being "funkedified", they seem okay after 22 years.
You could always stick a few of these in each hull.
http://www.rei.com/product/708992
After buying the expensive flotation bags from APS i found one of thse water bags in my garage and realized that they were very similar for 1/5th the cost of the APS bags.
edited by: TurboCat, Aug 11, 2010 - 10:08 PM
An inner tube does sound good they floated my ass down the river many times and never poped on the rocks in the river so they are pretty durable.
Edchris, Thats impressive!
