INSIDE OF A PRINDLE HULL
Does anybody has information on how the inside of a prindle hull looks like? I need to know if there are bulkheads underneath the posts, etc.
under the for beam is an aluminum "t" bar that is glassed to the keel. i'll try to get some pics up later.
they are pretty open. What prindle. Most have ports you can open and look at.
Why not shove a digital camera in through an access port and take pictures. You can tape it to a PVC electrical tube and use the self timer to get at nasty spots. You may need 50 attempts, but you will then have a good idea of what you are dealing with.
That's what I always do before attempting to use a chisel, saw or angle grinder etc.
