Here's the problem. After about an hour in light to moderate winds, I noticed my port chainplate had pulled away from the hull a bit, tearing the hull on either side as well. Scary. Brought it in, and on closer inspection, this is what I have;
The chainplate is riveted to the hull with 4 (5?) rivets. It looks like, and I can only assume this is the way it is built, that there is a backing plate that is riveted to the hull and chainplate. I'd love for someone to confirm if this is correct.
The top rivet has totally pulled out, the second is stretched. The lower ones are fine.
The hull has ripped for about 1.5 inches on either side of the chainplate. This is not good, and I really, really hope this is not overly structural to the attachment.
So, here are my questions. The first, obviously, is how did this happen? I can't think of a scenario where the chainplate could be pulled away form the hull. The only thing I can think of is I yanked out on it while getting out/off the wire. I wouldn't think that could tear the hull, though.
What's the fix? Ideally, I'd have a quick fix to get me through the season, and a "correct" fix once I have the boat back home and in the garage. I'm thinking for the quick fix, is to remove the blown rivets, replace, drill the end of the tears to keep the cracks from propagating, seal it and keep an eye on it untill a can strip and fix correctly.
I'd love to hear from any ne who's seen this, or can offer up help for the fix.
Chris
