Only if you sail solo more than 90%, I picked up my Harken furler and swivel for $110, jib for $75, does not slow down setup as the wire in the jib luff is my forestay, I attach jib with pigtail and swivel to mast tang along with shrouds and step mast. Has been a lifesaver for me, jib is furled for launching, before beaching and when beached, furl jib in emergency for those squalls that suddenly gust 30 mph plus, jib sail does not hang up when tacking. All in all, best $200 spent on this H16. In fact, I'm not too sure I can remember how to use the original H16 forestay with jib that clips to forestay.
I think if I wanted more speed, I would use the original jib but do away with the seperate forestay wire and convert the original jib into a furling jib by adding the swivel and furler and removing the battons. As long as the jib sail is secured to the wire running up the sleeve in the luff at the top and bottom thimbles, there should be no problem.
TurboHobo
H14T
P18
P16
