Lots of ways to make this easier on the trailer how well it works depends a bit I guess on the type and placement of your mast riser on your trailer. mine goes straight up from the trailer about 5-6 feet. I use a Winch attached to this. I tied off my front 2 trap lines with a piece of line through the thimble NOT THE DOG BONE to a point on the outside the front beam. not to tight but enough tension to keep the mast from swaying side to side when you start. I unhook a rear trap line and use a stainless steel carabiner to connect the thimble to the hook on my winch. I do not have a gin pole but would like one. You do all this right after you PINed the mast base in while your son is holding it on his shoulder or resting on something. Then have your son walk the mast up hand over hand until at the rear beam while you begin to winch it in. This give enough height to get a decent bite on it with the winch. Once you have it to where it is holding on it's own as far as he can reach make sure you are using ratcheting winch that is locked in and if needed you can hold it while he jumps up on the tramp. After some practice or with a small step stool he can probably do it while you stay at the winch. Once he is in position you can continue winching while he tends it with a little upward pressure. He really doesn't have to lift it just keep it center. He should always be ready to move quickly if something fails. Once vertical he can help unpin so it can rotate freely while you connect the forestay. The mast should not go anywhere as the trap wire is holding just a bit forward. it should be enough to connect the forestay. Once it is connected you remove tension unhook the trap line and replace it where it goes
As for halyards, my ring is connected where my boom connects and the other end get cleated off at eh bottom of the mast. However a figure * stopper knot may be enough to keep from disappear inside or up the mast. Similar with my jib halyard. When I put the boat away I make sure both ends are secured at the bottom of the mast. Also If you have to you can tip your boat over sideways on the beach to retrieve an errant halyard with a mind of it's own rather than un-stepping the mast.
With experience you'll find the best placement for side shrouds and traps lines to make sure they are not getting tangled on the way up
NO WINCH:
If you don't have or don't want to use a winch you can setup the same way for sway control then you or son gets on the tramp while the other walks it up and hands it off to the other. Then the person on the tramp levers it into place and the one on the ground goes around to attach the forestay while the other leans on it to hold it in place while being attached. Reverse fro take down just make sure whoever is on the ground does not stand right under it. Have them stand to the side and step in and grab it when they can reach it.
Member:
Utah Sailing Association
Check out "
Prindle Sailors" on Facebook.
