I looked up TC Dike on Google Maps, boy you guys have it made, warm weather & water all year, a protected Bay, plus being able to go out in the open chuck, though I bet that passage gets busy with really big boats.
Ha Ha, we used larger versions of those pumps to empty each float compartment when I was a bush pilot in the Arctic decades ago. If I remember correctly the Twin otters had 6 compartments each float, they were bloody big,12,000 lb capacity each & by the end of the summer all the little leaks were starting to add up. Management didn't want to pull the planes with only 3-4 weeks to go as rebuild could be 2-3 weeks. Sometimes 2 or 3 compartments could be 200-300 strokes, every morning. Call me a wuss, but that's when I decided the airlines were the better life! Or you had to have arms like Popeye & order spinach by the case.
Draining my Cat is childs play by comparison, even when I forgot to put the plugs in.
This is one of the actual ships I flew back in the mid '80s Picture taken by the Chief pilots son.
Here is the same bird 6 months later, near the north pole, repainted after a merge of companies. Look at the size of those pressure ridges in the ice.
edited by: Edchris177, Sep 14, 2010 - 07:06 PM
