Got a "deal" on a Nacra 5.2, and everything is in order except the prior owner kept the hull strapped down all the time, so there are pretty good indents on the back bottom of each hull where the rollers are (front has cradles -- thank goodness!).
I knew going into this that I would have to do a lot of hull repairs, but can the indentations be "sprung" back somehow? There are no stringers where the indents are, and the location is about a foot in front of the aft inspection port. I have considered putting a properly shaped piece of wood in the boat that should be the approximate shape the hull bottom should be in, drilling a hole through the bottom of the hull and up through the shaped piece, inserting a bolt, heating the area a bit, and tightening the bolt.
I have seen that repairs can be made for boats that have had rollers go through the hull bottoms; that isn't the case here, but is it fixable? I don't mind doing a bit of fairing, but I would like to minimize the cutting!!
Thanks. I am new to this, but these are awesome looking boats, and I had to have one!
bn
edited by: bn, Sep 15, 2010 - 09:58 PM
