Was probably my post you followed to make the pvc endcaps. Actually, my front endcap and front beam have two bungees running through them. The top one is, like Dave mentioned, to keep the front trap wire under control until you hike out. The bottom bungee is attatched to what we call the "chicken wire". It is a rope from the rear transom to the bungee. It is long enough to dangle almost to the waterline. You can use a large eyestrap riveted to the transom to tie it (I drilled a hole on the outside of the gudgeon and used a shackle). As you hike out, reach down, grab the rope and bring it up behind your butt. Tension from the bungee will help keep it there. For the crew, right hand on the jib sheet, left hand on the rope as you move up and down the hull to balance the boat. If the skipper "stuffs" the hulls and you suddenly decelerate, a good grip on the rope will prevent you from taking a trip around the forestay. Because of the front hull volume on the 5.0 it will usually just power out of that situation instead of pitchpoling,
but it is embarrasing for the crew to be looking back at the skipper from under the jib!
