Usually you don't dump unless the wind is over 15 mph. Technique is as important as sheer mass. First swim the mast around into the wind, or wind between mast & bows. Don't let go of the boat, pull yourself along the forestay.
Second, you cannot just hang like a sack from the righting line. You need the pivoting mass to be as far from the bottom edge of the hull as possible, think on your tip toes, totally horizontal, a foot off the water. For every degree that you are closer to vertical, you are decreasing your righting force. It takes arm & upper body strength to achieve that position, do some chin ups & sit ups. Using this method I have righted my Nacra 5.7 solo, without using the righting bag, & I only weigh 175, with wet gloves & life jacket!
I once had a hull with a bunch of water in it, I hiked out, & my buddy stood on my shoulders & hiked out to get it to come over. Remember the farther out you get the better, tall guys have an advantage, Damon should be able to right the Titanic
edited by: Edchris177, Sep 21, 2010 - 10:54 PM
