I have the bigger brother to the 5.0, an '84 5.7. Mine is an early '84, built in Feb, it came with pivmatics, captive mast ball, & adjustable raked spreaders.
You are an experienced sailor, maybe you should look for a 5.7?
I solo mine quite a bit,no problemo, you can't hold it down at full power in over 12-15 mph,(I'm only 170 lbs)so you use some of the multiple depowering devices & go out & have a blast. You can also take the entire family, 2 on the wire, the rest anywhere,& drive the crap out of it in 20+ winds, it rocks! I've buried BOTH hulls completely under,right up to the beam, rooster tails shooting from the front beam, & it won't pitchpole (mast raked somewhat).
I don't race, so I don't chase every last bit of pointing & speed, you gotta love the boardless Nacras, no boom,no boards, simple to rig & you can carry a ton of weight. Here are a couple of threads re the 5.0 & 5.7. Get one, Philip practically guarantees you will be inundated with naked nubile females on a Nacra.
Furling not standard, about a $200 investment, great addition when soloing. I'm putting together an album that shows what's involved. You can use your drum from the Trac, as Dave mentioned you need a swivel at top of forstay. I use the Harken small boat furler. You also need a way to attach the top swivel to the bow shackle on the mast hound, they make a tang for a few bucks.
You can cut the old forestay, have them put a marine eye on the end, instead of a thimble, you can cut the old one right at the thimble & put the eye on with only a few inches loss. You need 5" for the furler & 1 1/2" for the adapter tang at top. The marine eye you put on will attach directly to the forestay chain plate adjuster, the adjuster pins to the drum, you can stil adjust rake.
http://www.thebeachcats.com/module-forum-viewtopic-topic-12064.html
http://www.thebeachcats.com/module-forum-viewtopic-topic-12085.html
http://www.thebeachcats.com/module-forum-viewtopic-topic-11692.html
edited by: Edchris177, Sep 21, 2010 - 08:08 PM
